Unfortunately, I do not understand the question.countryboy wrote:I deleted the Wav file but since this is a Wild Media Trial is this why I'm not seeing/understanding the steps you listed?
Setup Questions
Re: Setup Questions
Re: Setup Questions
[/quote]
If you use individual settings of devices: Settings - Server - "The list of authorized client devices" - choose a device - Edit - Settings - Embedded file support - Music[/quote]
Eugene I figured out what you were saying so I deleted Wav from both places and Wav is no longer listed under supported files, so now what I need to be able to play Wav files?
I want to buy your product but not before you can figure out why I can't play Wav files.
Re: Setup Questions
Now wav-files must be sent through the transcoding. The player shows any information about music-resources ?countryboy wrote:Eugene I figured out what you were saying so I deleted Wav from both places and Wav is no longer listed under supported files, so now what do I do I need to be able to play Wav files?If you use individual settings of devices: Settings - Server - "The list of authorized client devices" - choose a device - Edit - Settings - Embedded file support - Music
