Hi, I am searching over whole forum but I cannot find solution
for my resources
How can I add http://pianosolo.streamguys.net:80/live
into WMS if I am using WD live profile/device
Player say always unsupported format
Second question is howto add http://downloads.bbc.co.uk/podcasts/wor ... ia/rss.xml and listen on WD player ?
I haven't any problem with adding into TVersity but with same URL
i am not able listen if i am using WMS
Shoutcast and RSSpodcasts
Re: Shoutcast and RSSpodcasts
To play online resources requires VLC (http://www.videolan.org). On the right mouse button you can select a profile transcoding "Music - Internet-Radio (VLC)". I have no problems with playing these resources WDTV Live.km123 wrote: I am searching over whole forum but I cannot find solution
for my resources
I am adding my URL into WMS\Music\podcast
then Addlink
D:\Program Files\Wild Media Server>"\vlc.exe" -Idummy --language en --sout=#tran
scode{acodec=mp3,ab=192,channels=2,samplerate=44100}:duplicate{dst=std{access=fi
le,mux=raw,dst="D:\DOCUME~1\a\LOCALS~1\APPLIC~1\WILDME~1\WMS\Temp\Test_fc4695d72
ed6efa6766266c81e235648.rss"}} "http://www2.rozhlas.cz/podcast/leonardo.rss"
'"\vlc.exe"' is not recognized as an internal or external command,
operable program or batch file.
EDIT/update I found Setup page / Media resources / Internet television
path for VLC I will try update path on my VLCportable directory
D:\Program Files\Wild Media Server>pause
I am using VLC standard also portable version on my PC
then Addlink
My problem is with path to VLC but I have no idea
why ?
I made copy of working VLC+libs (ver 0.9.8) under \Transcoders
wmstrans.cfg
why ?
wmstrans.cfg
<Transcoder>
<Name>VLC</Name>
<Path>Transcoders\vlc.exe</Path>
<HomePage>http://www.videolan.org</HomePage>
<Download>http://www.videolan.org</Download>
</Transcoder>
Settings-Transcoder-Profiles - specify the path to the installation directory for VLCkm123 wrote:My problem is with path to VLC but I have no idea
why ?
wmstrans.cfgCode: Select all
<Transcoder> <Name>VLC</Name> <Path>Transcoders\vlc.exe</Path> <HomePage>http://www.videolan.org</HomePage> <Download>http://www.videolan.org</Download> </Transcoder>
I had low screen resolution [Profiles] in lower left corner was not visible
Thanks for this I will open another thread becouse RSS articles
are not available I found somewhere IE is required is it right ?
I have WinXP Lite / removed IExploder is there any option solve this ?
hmm trying a shoutcast stream as a podcast now, with profile internet radio on a samsung LE37b650 tv.
Is it possible to get it work? When I start the stream on the tv I hear a loud noise, just like a radio without antenna
which profile are you using you TV should be able decode WAV/MP3
and if is different as supported you could hear a noise
this will help Eugene may be
http://downloadcenter.samsung.com/conte ... 9-1012.pdf
I have more information now, it's the url that cant be handled properly. http://shoutcast.omroep.nl:8268 doesnt work
http://78.159.104.165:80 works great.
I added both as internet radio with the Music - Internet radio (VLC) transcoding profile
