Hello, first to congratulate you on your program and wanted to discuss a problem. I have a TV Philips 7605 with the license purchased and when I play movies without transcoding because it plays on TV, when he takes a while playing the movie is out of sync audio with video, if I give to rewind or fast forward re-synchronize. It is connected by cable, not wifi.
Thank you very much and sorry because I'm from Spain.
Out of sync without transcoding
Re: Out of sync without transcoding
Yes, Philips TVs have this problem and users usually do the same.kano wrote:I have a TV Philips 7605 with the license purchased and when I play movies without transcoding because it plays on TV, when he takes a while playing the movie is out of sync audio with video, if I give to rewind or fast forward re-synchronize. It is connected by cable, not wifi.
Thank you very much for the reply Eugene. Then transcoding everything, i see the quality loss is minimal and let me problems. I use the default encoding (I think it's movies-primary), you think?
Thank you very much Eugene.
