Date format changed by WMS
LouisXIV
Post by LouisXIV »
Since I updated WMS it seems WMS is interfering with my Windows XP date format.
I'm using dutch XP. After starting WMS througout my complete Windows environment (explorer but also fe Excel) date is presented as 09.02.2010 instead of 09-02-2010 (my default).
After changing back the setting through config panel everything works fine, 'till next stop/start of WMS.
Re: Date format changed by WMS
LouisXIV wrote:Since I updated WMS it seems WMS is interfering with my Windows XP date format.
Fix will be in the next version, sorry.
LouisXIV
Post by LouisXIV »
No problem.... ;)
cubik
Post by cubik »
same problem here with the date format and also on my tv when i browse my computer files it writes 'my computer' in russian or something similar...
cubik wrote:same problem here with the date format and also on my tv when i browse my computer files it writes 'my computer' in russian or something similar...
update program
