Panasonic G20 and movies with AR higher than 16:9
Help other users and get free licenses Wild Media Server (UPnP, DLNA, HTTP)
fleggy
Post by fleggy »
Hello. After several hours I have succeeded in streaming high AR videos on my Panasonic TX-P50G20E. I suppose that similar method will work with other TVs.
One important change was increase Frame/Screen Hight from 1080 to 1088 in .cfg and in translator setting as well.
- use modified panasonic_viera_tv_dlna_wide_1920x1088.cfg
- modify script Movies (additional)
- change transcoder settings according to settings.txt in the attachment
Now my videos are treated as 16:9 and have appropriate black strips above and below the picture. Previously my videos were treated sa 4:3 and stretched to full screen. And finally I'd like to thank the user J.T.K. for his configuration file for Panasonic TV.
WMS 1.08 & Panasonic G20E.zip
(4.41 KiB) Downloaded 2143 times
fleggy
Re: Panasonic G20 and movies with AR higher than 16:9
Post by fleggy »
Hello everybody. I've just found out that everything what is needed is just one simple thing: set frame size to 1920 x 1088 in transcoder settings. Everything else is obsolete. Just use original J.T.K.'s panasonic profile, set transcoder frame size and enjoy widescreen :)
fleggy
Post by fleggy »
for current WMS (1.59.2) set this:
- Setting
- Devices
- select your TV and press Settings
- Codecs, Frame
- set Frame size to 1920 x 1088
- set Format 16:9
- set Change the original frame size to Always
I think that's all. If not check following (I am not sure what are default values/settings):
Frame: L, T, R, B all zeros, L, T, R, B checked
Active padding color checked
BR
Tomas
