IMDB...
libero
IMDB...
Post by libero »
Changed the layout... we need a new module to scrab
Re: IMDB...
libero wrote:Changed the layout... we need a new module to scrab
Explain what you mean
libero
Re: IMDB...
Post by libero »
The IMDB page with movie information changed layout, so the scarping to obtain movie pics and infos is not working anymore.
Re: IMDB...
libero wrote:The IMDB page with movie information changed layout, so the scarping to obtain movie pics and infos is not working anymore.
http://www.imdb.com/title/tt0499549/ - no problem
libero
Re: IMDB...
Post by libero »
more on this http://www.imdb.com/board/bd0000040/thread/170012668
and you can see the new version here http://labs.imdb.com
Re: IMDB...
Update on 1.05.3 - http://www.wildmediaserver.com/forum/vi ... &f=3#p3912
If was changes, then need load scripts from ?:\Program Files\Wild Media Server\wmsimdb.cfg
libero
Re: IMDB...
Post by libero »
Sorry to bother,
It worked in 1.05.3 but not works on later versions.
Am I doing something wrong ?
Libero
Re: IMDB...
libero wrote:Sorry to bother,
ivoets
Re: IMDB...
Post by ivoets »
I had the same problems...
Updated sometimes, but no go..
I got the same solution from the helpdesk, but did not understand the line "
Eugene wrote:Update on 1.05.3 - http://www.wildmediaserver.com/forum/vi ... &f=3#p3912
But after some puzzeling myself i found out you have to "re-load the script settings in your WMS-search window.
This finnaly solved my problem and started loading the IMDB information...
So if I get it right it should be:
- Download the latest distribution kit from http://www.wildmediaserver.com/download.php (not the update);
- If necessary erase the file ?:\Program Files\Wild Media Server\wmsimdb.cfg ; (not sure, but better safe then sorry)...
- Install the distribution kit;
- Start the program and select a media file to edit;
- Open the Search on website / imdb window and reload the settings by clicking on "load" button in the lower right corner;
- Browse to the Wild Media Server Install folder ( normally ?:\Program Files\Wild Media Server\ ) and select the file "wmsimdb.cfg" ;
- there will be a question to clear the current list,
o selecting "Yes" will erase all settings and load the now ones (recommended);
o Selecting "No" will keep your old settings and add the ones in the selected file.
Re: IMDB...
Location user's wmsimdb.cfg
Windows XP: ?:\Documents and Settings\All Users\Application Data\Wild Media Server\wmsimdb.cfg
Windows 7: ?:\ProgramData\Wild Media Server\wmsimdb.cfg
