As it says in the title.
When looking at a folder of 10 megapixel images the image on screen is displayed at almost thumbnail size.
Any ideas what the cause could be?
Pictures displaying onscreen as thumbnails
Re: Pictures displaying onscreen as thumbnails
New firmwarescamartist wrote:As it says in the title.
http://www.wildmediaserver.com/forum/vi ... &f=3#p3473
Settings - Device - "Embedded file support" - "The maximum number of pixels in photo" - 3686400 (1920x1920)
or Settings - Server - device - Edit - Settings
The firmware is the same but was using older version of Wild Media Server and pictures were fine.
Will have a look at the settings you mentioned when I get home from work.
Thanks for your help.
Yes, this problem was not, solution for 1.04.7scamartist wrote:The firmware is the same but was using older version of Wild Media Server and pictures were fine.
Settings - "File types" - jpg - Edit - DLNA
DLNA.ORG_PN=JPEG_MED;DLNA.ORG_OP=01;DLNA.ORG_CI=0
Thanks Eugene thats it fixed now.
