Í am currently testing the software and it looks good.
I've only got an issue with dutch subtitles.
Setting the default to nl or nld in settings, does not achieve anything.
Workaround is to select the subtitle on each individual file.
This works, but causes the picture to be stretched. No issue with the workaround already posted here by eithet setting the device on 4:3 or use a different profile.
However when using a Video_TS folder as the source, one has to select the subtitle on each individual file.
Even worse on using the "Watch folder" having to select the subtitle on each individual cell.
What am I doing wrong here ?
NL Subtitles
Re: NL Subtitles
You can use a playback through a folder Transcoding or turn on "Creating DVD-structure folders for DVD-directories" (Settings - "Media-Resources" - Scanning).zImage wrote:Í am currently testing the software and it looks good.
Re: NL Subtitles
Thx, the "creating dvd structure..." works.Eugene wrote: You can use a playback through a folder Transcoding or turn on "Creating DVD-structure folders for DVD-directories" (Settings - "Media-Resources" - Scanning).
Only thing is that it shows one large file for the complete movie and multiple small files(cells) for the chapter.
One large file is good, but I am not able to skip through the chapters(cells)
To do that I would neet to set subtitling on each individual cell.
A good option would be to be able to set the subtitle in the transcoding profile as you can set the profile at once over multiple files. Maybe it can already be done, but I haven't found out how yet.
Re: NL Subtitles
A script to set a subtitle language
Settings - Processing - Add
Click "Button on the main form"
Script:
Usage:
1. Select folder in Folders [Movies]
2. Click "Select Subtitle"
Script:
procedure ProcessItem(const aItem: TWmsScriptMediaItem; const aLanguage: string);
i, j: Integer;
sSubtitleList: string;
if VarToStr(aItem.Properties[mpiVideoCodec]) <> '' then begin
sSubtitleList := VarToStr(aItem.Properties[mpiSubtitleList]);
if sSubtitleList <> '' then begin
i := Pos(aLanguage, sSubtitleList);
if i > 0 then begin
j := i + Length(aLanguage);
while (j <= Length(sSubtitleList)) and (sSubtitleList[j] <> ',') do
Inc(j);
aItem.Properties[mpiSubtitleLanguage] := Copy(sSubtitleList, i, j - i)
end else if aItem.HasChildItems then
for i := 0 to aItem.ChildCount - 1 do
ProcessItem(aItem.ChildItems[i], aLanguage)
if WmsCurrentMediaTreeItem <> nil then begin
WmsShowInformation('Set subtitle language...');
try
ProcessItem(WmsCurrentMediaTreeItem, 'nl');
finally
WmsHideInformation
WmsDatabaseAutoSave;
ShowMessage('Setting the subtitle language completed');
ProcessMediaResult := True
Re: NL Subtitles
Great, thx very much. This works.Eugene wrote:A script to set a subtitle language
Script:Usage:Code: Select all
procedure ProcessItem(const aItem: TWmsScriptMediaItem; const aLanguage: string); var i, j: Integer; sSubtitleList: string; begin if VarToStr(aItem.Properties[mpiVideoCodec]) <> '' then begin sSubtitleList := VarToStr(aItem.Properties[mpiSubtitleList]); if sSubtitleList <> '' then begin i := Pos(aLanguage, sSubtitleList); if i > 0 then begin j := i + Length(aLanguage); while (j <= Length(sSubtitleList)) and (sSubtitleList[j] <> ',') do Inc(j); aItem.Properties[mpiSubtitleLanguage] := Copy(sSubtitleList, i, j - i) end end end else if aItem.HasChildItems then for i := 0 to aItem.ChildCount - 1 do ProcessItem(aItem.ChildItems[i], aLanguage) end; begin if WmsCurrentMediaTreeItem <> nil then begin WmsShowInformation('Set subtitle language...'); try ProcessItem(WmsCurrentMediaTreeItem, 'nl'); finally WmsHideInformation end end; WmsDatabaseAutoSave; ShowMessage('Setting the subtitle language completed'); ProcessMediaResult := True end.
