Update file from version 1.02
How to update the program:
1. Download the update file.
Wild Media Server (UPnP, DLNA, HTTP) v.1.03
1. Folder of podcasts feeds:
- ability to create a list of podcasts feeds using the script,
example of using "Watch TV Shows", "TheWB", "NBC - Shows" in
Podcasts Gallery.
2. The distribution includes a Bulgarian translation file (Help - Language),
translated by user aka S@gittarius, many thanks.
3. Scripts:
- added function WmsSendRequestEx, additionally you can set
call parameters INTERNET_FLAG_xxxx and get response header,
an example using "Watch TV Shows" in the Podcasts Gallery.
4. Updated configuration for Sony TVs and Samsung TVs:
added configuration automatic remux files with DTS audio track,
use profile transcoding "Movies - TsMuxer", editing: Settings -
File Types.
5. Profiles transcoding:
- updated profile transcoding "Internet-television", changed formation parameter
"Aspect Ratio".
