HI, Eugene:
Can you give me some chinese podcasts of *.wdf file , (
for example www.youku.com ,www.tudou.com )
ABOUT CHINESE PODCAST
Re: ABOUT CHINESE PODCAST
Thanks your youku.zip .
As you said ,the "rtmpdump.exe" must be use to access the network .
When I press settings--profiles, in the "transcoder list", I can add and setup "transcoders\rtmpdump.exe".
But in the "transcoder profiles list", I cannot setup "transcoding parameter" for rtmpdump.exe , can you help me?
Youku do not use rtmpdump.exe. You need to add rules for rtmpdump.exe in your firewall program, if you have a problem with the test transcoding (MTV, FOX, ...).kk6910kk6910 wrote:Thanks your youku.zip .
does anyone know how to add youku playlists in wms?
With youtube it's easy
for example this link: http://www.youku.com/playlist_show/id_3416083.html
thx
thx
Now I get the thumbnails in my wms, and I see the list on my TV. But still there is a playback error for everything. If I start test-transcoding the console displays the following:
FFmpeg version SVN-r25118, Copyright (c) 2000-2010 the FFmpeg developers
built on Sep 24 2010 21:37:50 with gcc 4.5.0
[flv @ 022efe90] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 15.00 (15/1)
Input #0, flv, from '\\.\pipe\892EB13C225C4ECAA364AC05620FFB54':
Metadata:
metadatacreator : Yet Another Metadata Injector for FLV - Version 1.4
hasKeyframes : true
hasVideo : true
hasAudio : true
hasMetadata : true
canSeekToEnd : false
duration : 422
datasize : 13051713
videosize : 10397522
videocodecid : 2
width : 320
height : 176
framerate : 15
videodatarate : 191
audiosize : 2564195
audiocodecid : 2
audiosamplerate : 22000
audiosamplesize : 16
stereo : true
audiodatarate : 44
filesize : 13054036
lasttimestamp : 422
lastkeyframetimestamp: 416
lastkeyframelocation: 12889077
Duration: 00:07:02.19, start: 0.000000, bitrate: 240 kb/s
Stream #0.0: Video: flv, yuv420p, 320x176, 195 kb/s, 15 tbr, 1k tbn, 1k tbc
Stream #0.1: Audio: mp3, 22050 Hz, 2 channels, s16, 45 kb/s
Output #0, dvd, to 'C:\Users\Diddi\AppData\Local\Wild Media Server\WMS\Temp\Test
_1a3a63d9bce053a8c6c784c93f546f59.mpg':
: Video: mpeg2video, yuv420p, 320x176 [PAR 44:45 DAR 16:9], q=2-31, 10000 kb/s,
90k tbn, 15 tbc
: Audio: ac3, 48000 Hz, 2 channels, s16, 448 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Error while opening encoder for output stream #0.0 - maybe incorrect parameters
such as bit_rate, rate, width or height
Drücken Sie eine beliebige Taste . . .
/1) -> 15.00 (15/1)
Metadata:
hasKeyframes : true
hasVideo : true
hasAudio : true
hasMetadata : true
duration : 422
datasize : 13051713
videocodecid : 2
width : 320
height : 176
framerate : 15
videodatarate : 191
audiosize : 2564195
audiocodecid : 2
stereo : true
audiodatarate : 44
filesize : 13054036
lasttimestamp : 422
90k tbn, 15 tbc
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
OK, I got it,
changed the TC profile to TS Muxer and now it works!
Thx again
Thx again
