What happens after the re-selection, there are no problems?kerio wrote:Music->Internet radio-->radiostations itunes-->added example ah.fm..after 30 seconds it stops channel and only way to get it work is click again same channel..is there somekind of settings for this one?
bd390 radiostations itunes
Re: bd390 radiostations itunes
Try to set the duration 01:00:00 in properties of radiostationkerio wrote:Same..after 30 seconds it stops again..it doesnt matter what channel i use. All make same thing..Eugene wrote:What happens after the re-selection, there are no problems?kerio wrote:Music->Internet radio-->radiostations itunes-->added example ah.fm..after 30 seconds it stops channel and only way to get it work is click again same channel..is there somekind of settings for this one?
Right place. In what format transcodes music? Music (not internet radio) through the folder Transcoding playing?kerio wrote:you mean internet radio-->ah.fm music information-->duration, i put 01:00:00.00 but there is no effect..is this right place to set duration or is there somekind of different place?..38 second and channel stop..Eugene wrote:Try to set the duration 01:00:00 in properties of radiostationkerio wrote:Same..after 30 seconds it stops again..it doesnt matter what channel i use. All make same thing..Eugene wrote:What happens after the re-selection, there are no problems?kerio wrote:Music->Internet radio-->radiostations itunes-->added example ah.fm..after 30 seconds it stops channel and only way to get it work is click again same channel..is there somekind of settings for this one?
According to the specification http://certification.dlna.org/certs/REG04107787.pdf BD390 does not support MP3. Settings-Transcoder - "Transcoding file params" - Internet-radio - select extension s16be, Transcoding Profile "Music - Internet-Radio (VLC)".kerio wrote:Music - Internet-radio (VLC)..MP3Eugene wrote:Right place. In what format transcodes music? Music (not internet radio) through the folder Transcoding playing?kerio wrote:you mean internet radio-->ah.fm music information-->duration, i put 01:00:00.00 but there is no effect..is this right place to set duration or is there somekind of different place?..38 second and channel stop..Eugene wrote:Try to set the duration 01:00:00 in properties of radiostationkerio wrote:Same..after 30 seconds it stops again..it doesnt matter what channel i use. All make same thing..Eugene wrote:What happens after the re-selection, there are no problems?kerio wrote:Music->Internet radio-->radiostations itunes-->added example ah.fm..after 30 seconds it stops channel and only way to get it work is click again same channel..is there somekind of settings for this one?
