VEVO (http://www.vevo.com)
VEVO (http://www.vevo.com) - required version 1.77
vevo.zip
(7.45 KiB) Downloaded 1909 times
2. Drag and drop vevo.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "VEVO". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file vevo.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "VEVO", you can create first level of VEVO navigation.
:!: Service only available in the United States :!:
Additional parameters - select the folder "VEVO" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Video count (by default 70):
--videocount=NN
Maximum bitrate (by default 3000 kbit/s):
--maxbitrate=NNNN
Re: VEVO (http://www.vevo.com)
Updated (added parameter "Maximum bitrate")
