Australian TENplay (http://tenplay.com.au/)
Australian TENplay (http://tenplay.com.au/) - Australian Channel Ten, Eleven, One - required version 1.77
au_ten.zip
(5.17 KiB) Downloaded 1836 times
2. Drag and drop au_ten.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Australian Channel Ten". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file au_ten.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Australian TENplay", you can create or update first level of Australian TENplay.
Additional parameters - select the folder "Australian TENplay" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Video count (by default 50):
--videocount=NN
Updated 2014/03/07
Re: Australian TENplay (http://tenplay.com.au/)
Updated 2014/03/07
