Australian Channel Eleven (http://eleven.com.au/)
Locked
Australian Channel Eleven (http://eleven.com.au/) - required version 1.77
au_eleven.zip
(4.01 KiB) Downloaded 1341 times
2. Drag and drop au_eleven.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Australian Channel Eleven". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file au_eleven.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Australian Channel Eleven", you can create or update first level of Australian Channel Eleven.
Additional parameters - select the folder "Australian Channel Eleven" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Video count (by default 50):
--videocount=NN
Re: Australian Channel Eleven (http://eleven.com.au/)
Locked
