Fox (http://www.fox.com/shows)
Fox (http://www.fox.com/shows) - required version 1.77.1 (64-bit) | 1.77.1 (32-bit)
fox.zip
(6 KiB) Downloaded 1767 times
2. Drag and drop fox.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Fox. If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file fox.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder Fox, you can create or update first level of Fox navigation.
Additional parameters - select the folder Fox - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Subtitles support:
--subtitles=on
Updated 2014/03/06
Re: Fox (http://www.fox.com/shows)
Updated
Updated 2014/03/06
