Hi
First of all, thanks for the program, it's just great.
But I wanted to know, how a collection folder could automatically add videos to itself from a folder of my computer? For example, I made a collection named "Classical movies" and I have a folder called "Classical movies" on my computer. And when I add a movie to the folder on my computer, then it goes to the all movies and in the "Classical movies" collection.
I am not good at explaining things...
Auto-updating collection?
Re: Auto-updating collection?
Click Renew in the main form of the program.
In version 0.72.5 added dynamically generated folder, you can use this feature. In the folder tree on the right mouse button "Edit title", select "Dynamic (script)", press button Scriptogre111 wrote: But I wanted to know, how a collection folder could automatically add videos to itself from a folder of my computer? For example, I made a collection named "Classical movies" and I have a folder called "Classical movies" on my computer. And when I add a movie to the folder on my computer, then it goes to the all movies and in the "Classical movies" collection.
mfVideoWatchFoldersItemID = 'B7A1EE6A-CE07-4E09-B5ED-E51D22BBE743';
iPathOffset: Integer;
WatchFolder: TWmsScriptMediaItem;
function FindWatchFolder(aFolder: TWmsScriptMediaItem; const aTitle: string): TWmsScriptMediaItem;
Result := nil;
if (aFolder <> nil) and aFolder.HasChildItems then
for i := 0 to aFolder.ChildCount - 1 do
if aFolder.ChildItems[i].HasChildItems then begin
if SameText(aFolder.ChildItems[i].Properties[mpiTitle], aTitle) then
Result := aFolder.ChildItems[i]
else
Result := FindWatchFolder(aFolder.ChildItems[i], aTitle);
if Result <> nil then
Break
procedure ProcessFolder(aFolder: TWmsScriptMediaItem);
Item: TWmsScriptMediaItem;
for i := 0 to aFolder.ChildCount - 1 do begin
Item := aFolder.ChildItems[i];
if Item.HasChildItems then
ProcessFolder(Item)
else
FolderItem.AddItem(Copy(ExtractFileDir(Item.Properties[mpiFilePath]), iPathOffset, 1024), Item)
WatchFolder := FindWatchFolder(WmsFindMediaFolder(mfVideoWatchFoldersItemID, ''), 'Classical movies');
if WatchFolder <> nil then begin
iPathOffset := Length(IncludeTrailingBackslash(WatchFolder.Properties[mpiFilePath]));
ProcessFolder(WatchFolder);
Thanks for the quick reply.
I don't seem to get it working. I updated to 0.72.5, added a collection " Movies ", then "edit name" chose "dynamic script" , pressed "script", copied the code you sent and pressed ok. Then I made a folder " Movies " in my computer and added it to the media resources of the program.
I renewed it, closed the program and started again, but nothing seems to work.
No files seem to appear in the collection.
