Sound goes demonic after playing video for some time
SNiLD
Post by SNiLD »
After playing some videos the sound of them goes demonic (usually right after scene changes). If I replay the same file that has been saved by WMS for pre-transcoding the same happens. If I replay the original file with Media Player Classic Home Cinema there is no problem.
Re: Sound goes demonic after playing video for some time
SNiLD wrote:After playing some videos the sound of them goes demonic (usually right after scene changes). If I replay the same file that has been saved by WMS for pre-transcoding the same happens. If I replay the original file with Media Player Classic Home Cinema there is no problem.
You can upload an example of a problem file to rapidshare.com and specify the time of the problem?
SNiLD
Post by SNiLD »
Eugene wrote:You can upload an example of a problem file to rapidshare.com and specify the time of the problem?
The resulting and original files are waaaaaay too big to be uploaded anywhere. The file it generates (d5eb16bddf328700c2dbde9ea768c28e.mpg) is 2,33GB and I was unable to cut it at all. This file is generated by WMS from "24.s08e01.720p.hdtv.x264-immerse.mkv". Maybe you can find it from alternative sources? It's 1,09GB. The sound turns demonic after 23:55.
The problem exist, with what is related, I do not know, when the test transcoding is no errors. Helps the choice playback from 25 minute through a folder Transcoding (setting intervals start playing - Settings-Media-Resources-Service)
