Test transcoding works ?
UN46C7000: ¿WMS 1.09.1 is not transcoding?
Re: UN46C7000: ¿WMS 1.09.1 is not transcoding?
click Devices - the list must be empty or check settings
I checked http://www.youtube.com/watch?v=Zm3Ih5JV8Ss on Samsung TV - no problems
Select the folder "Youtube" - right click - "Edit title" - "Transfer resource to the media device" - click TranscodingSMatanza wrote: YES. The "test transcoding" command works but in the TV the message is always "Not supported file format". I'm attaching some images and the log file:
Settings - Device - "Embedded file support" - Movies - remove flv
or (individual settings of device)
Settings - Server - choose a device - Edit - Settings - "Embedded file support" - Movies - remove flv
