Update to 3.01 (x64) (2.86-3.02) (3.01-3.02)
Wild Media Server (UPnP, DLNA, HTTP) v.3.00-3.01
1. Media resources (navigation on media device):
- added folder "UPnP (DLNA) servers":
- the ability to play media resources UPnP (DLNA) servers found on your home network via a Web navigation;
- the ability to play media resources with transcoding;
- the ability to play music and photos through folders Music (Visualization) and Photo (Slideshow).
- Transfer mode selection of media resources:
- Transcoding;
- Original link;
- Original stream;
- Original link (redirect);
- selection mode "Create Item Folder" (folder contains all the media resource formats, that provides source media server);
- selection frame height for transcoding.
- added the ability to disable unused formats;
- added the ability moving format using the "mouse" to desired position.
- If the mode "Include in the description of supported files the links with transcoding" is turned on, the program includes to a UPnP (DLNA) description of a media resource links with transcoding into all active formats from the page Settings - Transcoder - "Format parameters".
