I've upgraded WMS from version 1.78.2 to 2.00 and my Denon AVR-2313 stopped being able to play content.
I select Network on Denon, then Media Server, select my media server, I get green screen splash and nothing after that.
I tried already re-installing 2.00 using distribution kit, but it doesn't help.
I can still play some music content from WMS onto receiver by using "play in" function, but that's not a solution.
How can I roll back to version 1.78.2 or fix the issue?
My Denon is registered with appropriate license key and the type defined as "AV Receiver".
Denon AVR stopped playing content after WMS upgrade
Re: Denon AVR stopped playing content after WMS upgrade
Settings - Devices - choose a device - Settings - "UPnP, DLNA" - "Media resources identifiers" - button "Structure of media resources" - the folder Media - right click - "Edit title/settings" - button "Script"
replace
with
Ok - ...
replace
WmsDatabaseLinkFolder("0972345A-4255-4ECA-98A1-F326465BA727", FolderItem.ItemID)Code: Select all
WmsDatabaseLinkFolder('0972345A-4255-4ECA-98A1-F326465BA727', FolderItem.ItemID)Re: Denon AVR stopped playing content after WMS upgrade
It helped, thanks a lot!
Shall I do it for other devices as well?
(I also seem to have same issue with my Brava TV set)
This solution only for device configuration "AV Receiver"ironman wrote:It helped, thanks a lot!
Some solutions for Sony Bravia 2014 - viewtopic.php?f=7&t=2238ironman wrote: (I also seem to have same issue with my Brava TV set)
Thank you very much again, I will look into these!
