Sorting options
LouisXIV
Sorting options
Post by LouisXIV »
If possible: sorting options.
When using the main WMS window you can sort views by clicking a column. It would be great if these sorting preferences could be saved per view, so you could have different sortings like
- Music -> Albums -> by track no
- Music -> Artist -> Year
etc.
and that these sortings are past on to the device so that when I am browsing on the TV it sorts like in the main WMS window.
Re: Sorting options
LouisXIV wrote:If possible: sorting options.
etc.
The program will configure the structure base media resources. I think it will sort field by default.
Re: Sorting options
cmk001 wrote:Please advise how to remove/re-arrange unwanted columns in Movies List area.
Remove - right click mouse Customizing (drag and drop column header)
Re-arrange-using the mouse to move the column header in the desired position
Re: Sorting options
cmk001 wrote:To sort out multiple podcasts into sub-folders under Podcasts, cannot drag and drop podcasts from main Podcasts folder to subfolders like You Tube, Daily Motion etc. Please advise.
Instead of folders you can create a collection (podcast).
