Wild Media Server (UPnP, DLNA, HTTP) v.1.78
1. Updated transcoder ffmpeg-1.dll (version 2.0, adds support for https-links).
2. Scripts:
- added functions WmsOAuth... - support OAuth-authorization;
- added function WmsExecuteByTimer - executing a script by timer (can be call of procedure with parameters, the declaration of which in the script, that called WmsExecuteByTimer);
- added function WmsInputDialog - shows a dialog for text input;
- in class TWmsScriptMediaItem added method CopyProperties - copying the properties of media resource;
- added variable InteractiveMode (True, if the script called by user);
- added variable ServiceMode (True, if the server is operating as Windows service);
- added functions GlobalVar ... (support for global variables, the values which are stored while the program is running and available from different scripts);
- added functions WmsPercentEncode and WmsPercentDecode - support for Percent-coding;
- added property mpiChildItemsExpiresInterval, can be set for the folders of media resources, that are created in the script and requiring periodic re-creation of child elements (unit - second).
4. Podcasts:
- added transfer mode "Original link (redirect)".
