Wild Media Server (UPnP, DLNA, HTTP) v.1.52
1. The main form of the program:
- added panels of buttons, that duplicate context menus of structure and list of media resources;
- to panels of structure of media resources added the column "Sort Order";
- to list of movies added the columns "Series Name", "Season No", "Episode No", "Episode Name", can be filled with loading information
from online database of series.
- added the mode "Automatic loading information" (available, if the settings of the database have a script that generates tabular results);
- added the possibility of converting search keywords by using Google Transliteration;
- added navigation buttons for the current list of media resources;
- added scripts for IMDb Germany (IMDB.DE), IMDb France (IMDB.FR), IMDb Italy (IMDB.IT), IMDb Spain (IMDB.ES), IMDb Portugal (IMDB.PT).
- added the folder "Sort" - choice sort of media resources in the current folder of media resources and child folders of media resources
(disabling the folder in settings of the program). After choosing the sort need to move from the current folder to generate a list media
resources in the selected sort order, you may need restart the server or device, if the device caches a list of media resources.
- in the "Folder list" added the column "Exclude hidden files, directories";
- to page "Service" added settings of folder "Sort order" - the choice of fields to sort, when you navigate on the media device.
- added the field "Sort order".
1. Added support for transcoding music with visualization modules. Supported types of visualization modules: Windows Media Player, Winamp, BassBox, Sonique. Working capacity the modules may depend on computer graphics system.
2. Folder "Movies":
- Added folder "Music (Visualization)". Through the navigating on the media device, you can select the active visualization module or turn on the random selection of visualization module.
- in the status bar added the button "List of music visualization modules" (configure of modules, choose the default module).
- added settings of music visualization.
6. Added device configurations:
- "Samsung TV [E] (DLNA, 16:9, 720x406)".
- you can specify a negative value, in this case the padding of transcoded file will occur until the end of play media resource (determined by the duration of a media resource) + specified value (absolute).
New version wmssfx.exe (Visualization module) for 1.52.3 - fixed possible problem with uncompleted video
Unzip, copy wmssfx.exe to ?:\Program Files\Wild Media Server
