I've started seeing a problem with WMS running as a service (don't know if this is specific to "service" mode, or the problem is more general).
When I start the computer (and WMS starts automatically with it) it consumes ~35MB of memory.
However after having played couple of movies, the memory consumption keeps growing (I've observed virtual memory sizes of ~1,8GB)
This takes down my computer performance + I believe recently became a reason for more often freezes of WMS service - need to go to the computer and restart the service manually, in order to be able to browse my media folders on the TV (after restarting the service memory concumption is again back to normal).
Please advise on what additional information you'd need in order to fix this...
Memory leak?
Re: Memory leak?
Settings - Transcoder - "Transcoding buffer" ?
Re: Memory leak?
Buffer for video is set to 500MB.
Re: Memory leak?
You can try disable "Transcoding buffer"krzychol wrote:Buffer for video is set to 500MB.
