DRM MMS???
gool54
DRM MMS???
Post by gool54 »
i have some mms link of live tv that i payed for to watch on my computer , when played with vlc they look like crypted with wmp11 works fine iam using wild media server to stream them into my tv but they are not working!! is there way to play drm live mms with Wild media server???? or change the core to wmp? thanks a lot for the help!
Re: DRM MMS???
gool54 wrote:i have some mms link of live tv that i payed for to watch on my computer , when played with vlc they look like crypted with wmp11 works fine iam using wild media server to stream them into my tv but they are not working!! is there way to play drm live mms with Wild media server???? or change the core to wmp? thanks a lot for the help!
In MONOGRAM GraphStudio 0.3.2.0 (http://blog.monogram.sk/janos/2009/06/1 ... udio-0320/) try File - Render URL, if the graph will be constructed and it can play (Start the graph), then I think you can connect to WMS.
gool54
Re: DRM MMS???
Post by gool54 »
well it's does not work means WMS doesn't support DRM files or link that's sad :(
Re: DRM MMS???
gool54 wrote:well it's does not work means WMS doesn't support DRM files or link that's sad :(
This means that there is currently no accurate information as they connect to the WMS :)
gool54
Re: DRM MMS???
Post by gool54 »
well i tried playon and it does support well the DRM videos and mms DRM link
i wish i could use WMS for everythings as WMS handel very well sopcast well now i need to switch between both.
Re: DRM MMS???
gool54 wrote:well i tried playon and it does support well the DRM videos and mms DRM link
Which service provides DRM mms?
gool54
Re: DRM MMS???
Post by gool54 »
sorry didnt answer before , well the DRM mms are from french live tv called canal+
when i tried them on vlc they look crypted and when used them with WMP 11 they work very good, well vlc dosent support DRM and i guess the core of WMS use Vlc
Re: DRM MMS???
gool54 wrote:sorry didnt answer before , well the DRM mms are from french live tv called canal+
To play DRM content must obtain a license from Microsoft, support will be later.
