How to update the program:
1. Download the update file.
Wild Media Server (UPnP, DLNA, HTTP) v.1.10
1. Changes in working with database of media resources.
2. Added selection of reading mode properties of media resources (Off,
Synchronous, Asynchronous): Settings - "Media-Resources" -
"Reading of properties".
3. Web-navigation now does not require licensing (may be used on
computers, mobile and PDA-devices) through the viewer for the Internet.
4. Added device configuration:
- - "LG TV (DLNA, 16:9, 720x406)";
- "XBOX 360 Live (DLNA, 16:9, 720x406)";
- "XBOX 360 (DLNA, 16:9, 720x406)".
6. In the settings of device, connection added the mode "Check IP-address"
(Settings - Devices - choose a device - Edit). Default off. If the devices are
connected via a bridge, it is necessary include checking of IP-address.
7. In the password for access to restricted resources now can be used
only the different digits.
8. In the setting of grouping of media resources added field "Allowed values".
9. Changes in the program settings:
- - settings of the device by default moved to a separate form
(calling from the field "Device type by default");
- the list of authorized client devices moved from section Server
to section Devices;
- list of events moved from the "Advanced" to the separate section "Events";
- changes in the form "Individual settings of the client device".
- - in the list of media resources, adds the ability to set status
"Hidden media resource" (in the menu on the right mouse button);
- in the folder tree of media resources added the ability to hide all
child items of the selected folder (in the menu on the right mouse button).
- in the configuration of devices added script to automatically determine the type of device (Settings - choose a device - Settings - Type - the last button "Auto-detect type of device"). Device configuration are not automatically updated, so you need to restore the configuration from the distribution (Settings - choose a device - Settings - Type - the button "Restore from the ditribution kit") or copy all files from ?:\Program files\Wild Media Server\DISTR\Devices\ to ?:\Program files\Wild Media Server\Devices\. Setting for Autodetect mode - Settings - Devices - Autodetect
- jumping to the form of the localization program (Ctrl + Shift + double click by control, Ctrl + Shift + select a menu item);
- updated Bulgarian, German translation files;
- updated transcoder ffmpeg-1.dll (support for Composer, Conductor in m4a-files);
- updated transcoder rtmpdump.exe (support for justin.tv);
- changes for Panasonic devices (subtitles, settings for UPnP-sorting - Settings - Devices - choose a device - Additional - "DLNA, UPnP options");
- changes for device configuration "LG TV (DLNA, 16:9, 720x406)";
- in transcoding options added file format MPEG1, video codec MPEG1
- added settings for default duration of internet-resources (Settings - "Media-resources" - "Internet-resources" - "Internet radio"; "Internet - television").
Update to version 1.10.2
- changes in the formation of DVD-structure. At scanning to the DVD-folder will be added links of the main chapters of DVD;
- added new settings for DVD-structure (Settings - "Media-Resources - Scanning - "Creating DVD structure folders for DVD-directories"): "The minimum duration of the main chapters", "Hide DVD-structure folders (by default)";
- settings for DVD-episodes are now common in Chapter;
- updated Polish translation file;
- updated the transcoding profile "Movies - CoreAVC", added support for transcoding avi, flv, mp4-files with H264 video encoding;
- updated the transcoding profiles "Internet-television", "Internet-television (Remux)", added support for selecting the audio track;
- updated the transcoding profile "Music - RTMPDUMP - FFMPEG", added support for the specified RtmpDump command line in the field Path;
- changes in Web-navigation for Firefox;
- added device configuration "VLC Media Player (Web, 16:9, 720x406)", can be used with any Internet Browser and VLC Media Player (free of charge).
