braviabob
Post by braviabob »
I have several HD mkvs which transcode to the test file but don't display on the TV. You've said in another post that Sony is very particular to h.264 encoding, I was trying to find out what implementation of h.264 it does understand?
Thanks for the DLNA white paper - unfortunatly it's a bit beyond my limited knowledge :)
braviabob wrote:I have several HD mkvs which transcode to the test file but don't display on the TV. You've said in another post that Sony is very particular to h.264 encoding, I was trying to find out what implementation of h.264 it does understand?
DLNA certificate KDL-37W5500 http://certification.dlna.org/certs/REG38765018.pdf
cg346
Sony Bravia .mkv files
Post by cg346 »
First of all, one of the best products I have ever seen! I've been spending hours and hours to get a connection from my Bravia to the Internet
Well, now it finally works! I have my Bravia connected via LAN to my Vaio laptop, from where I access my media server via WLAN
all movies show up nice and tidy on the TV and most formats work. MKV unforunately not, when I hit play I only get audio but no picture...
In "file types" I have .mkv to the transcoding profile: "Movies - Tsmuxer"
what is the best buffer size to set as some movies sometimes lag... is it even possible to stream 1080p mkv files via WLAN?
regards & thx in advance,
chris
cg346
Post by cg346 »
i seem to get audio now on all .mkv files, but still no picture... or sometimes just the "puzzle"
any hints?
tv is a bravia 32E5500
chris
cg346 wrote:i seem to get audio now on all .mkv files, but still no picture... or sometimes just the "puzzle"
any hints?
What are the settings for m2ts in Settings-File types?
cg346
Post by cg346 »
MIME:video/vnd.dlna.mpeg-tts
DNLA: AVC_TS_HD_24_AC3
transcoding profile: empty
cg346 wrote:MIME:video/vnd.dlna.mpeg-tts
Settings-Transcoder-Profiles-Movies-TsMuxer-mime-type: video/vnd.dlna.mpeg-tts ?
What video parameters in the original file (codec, frame size) ?
cg346
Post by cg346 »
all are H264 and as they are 720p: 1280x534/544/or else, frame rate 23.976
i basically read myself thru most posts and applied all the settings... but still don't get a picture... really weird
cg346 wrote:all are H264 and as they are 720p: 1280x534/544/or else, frame rate 23.976
I think for the Sony frame size should be 1280x720, 1920x1080. Only use the transcoding profile Movies (primary).
cg346
Post by cg346 »
i uninstalled the programm and install it again now and applying all the settings again, maybe it works...
so it is not possible to play other formats than 16:9? there is hardly a .mkv file exactly 16:9... also with .avi it works no matter what format
chris
