cfg file for Philips 2010 1920*1080
Here is the cfg file I created for my Philips 7605 and 9705 TV. Works fine with both my tv's. Enjoy
- philips_2010_dlna_wide_1920x1080.rar
- (2.67 KiB) Downloaded 2914 times
Re: cfg file for Philips 2010 1920*1080
Thanks for the profile. I copied your config and WMS started being smooth on my philips 7605 TV.
Wim
Wim
Ok!Rudiboy wrote:Here is the cfg file I created for my Philips 7605 and 9705 TV. Works fine with both my tv's. Enjoy
Can I use this cfg profile with 32pfl7606d_78 model (It's compatible)?
At least, you can try.
