Links to the problematic media resources
Re: Links to the problematic media resources
DEvil HUnter wrote:the key has the value 2..
tryed the value 0 - no effect...
(have win 7 pro)
the path i have problem with is:
i think the problem is the ü as before..
D:\Musik\christina stürmer\videos\Christina Stürmer - Mehr Waffen Video.avi
Change the value has no effect on old catalogs, only the new and requires rebooting.
In any case, i will try to invent something to solve the problem.
Rocko
Post by Rocko »
Hi, I have the same problem with the German umlauts (äöü). Is there already a solution?
Thank you for the WMS, otherwise it works perfectly with my SONY Bravia.
Sorry my english is not the best.
Rocko wrote:Hi, I have the same problem with the German umlauts (äöü). Is there already a solution?
If your native language contains German umlauts (äöü), try switching to the Regional Settings (Control Panel) the native language for non-Unicode programs. The program is a fix for this problem, but it seems it does not always work.
ha100
Post by ha100 »
"RTVTelevision 80s 90s Top Hits" from Shoutcast tv http://www.shoutcast.com/sbin/tunein-tv ... ?id=175658 does not play on W5500. Plays fine on PS3.
Tried transcoding profiles internet tv, internet tv demux, internet tv input stream, Movies (Primary). Wil try some more but don't think it will work. This channel has a stange resolution. Very small image.
DLOQUET
Post by DLOQUET »
I think I have the same problem with accented characters in French.
below the console when I test with a file containing accented characters:
C:\WMS>"C:\WMS\wmsmpeg.exe" -i "C:\Users\user\Music\Sonerien Treujenn Gaol\Son
neurs de clarinette en BRETAGNE\01 Daßs faßch an Danou½t.wma" -f s16be -ac 2 -ar
 44100  "C:\Users\Didier\AppData\Local\Wild Media Server\WMS\Temp\Test_ea4ba6e4d
47fb5a61f5fd6b5d141b239.s16be" -v -1
FFmpeg version SVN-r20212, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  built on Dec 19 2009 00:45:55 with gcc 4.2.4 [Sherpya]
  libavutil     50. 3. 0 / 50. 3. 0
  libavcodec    52.37. 0 / 52.37. 0
  libavformat   52.39. 0 / 52.39. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0. 7. 1 /  0. 7. 1
  libpostproc   51. 2. 0 / 51. 2. 0
C:\Users\user\Music\Sonerien Treujenn Gaol\Sonneurs de clarinette en BRETAGNE\
01 Da?s fa?ch an Danou?t.wma: no such file or directory
C:\WMS>pause
Appuyez sur une touche pour continuer...
And below the console when I test with a file without accented characters:
C:\WMS>"C:\WMS\wmsmpeg.exe" -i "C:\Users\user\Music\Louise Attaque\Louise Atta
que\01 Amours.wma" -f s16be -ac 2 -ar 44100  "C:\Users\Didier\AppData\Local\Wild
 Media Server\WMS\Temp\Test_a43145bdd4ffb3f69854f2fbf9353674.s16be" -v -1
Input #0, asf, from 'C:\Users\user\Music\Louise Attaque\Louise Attaque\01 Amou
rs.wma':
  Duration: 00:01:57.63, start: 1.579000, bitrate: 130 kb/s
    Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 128 kb/s
  Metadata
    Lyrics          :
    MediaPrimaryClassID: {D1607DBC-E323-4BE2-86A1-48A42A28441E}
    WMFSDKVersion   : 11.0.6001.7001
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
    Year            : 1998
    EncodingTime    : 2100859008
    UniqueFileIdentifier: AMGa_id=R   375646;AMGp_id=P   320476;AMGt_id=T  51400
55
    Composer        : Gaëtan Roussel
    Publisher       : Atmospheriques
    Genre           : World
    AlbumTitle      : Louise Attaque
    AlbumArtist     : Louise Attaque
    MCDI            : E+96+230C+5903+87DC+A98F+D5FC+1000E+11F35+142A0+17C8E+1AED
2+1E645+21101+270C6+2AD70
    Provider        : AMG
    ProviderStyle   : Rock
    PeakValue       : 32545
    AverageLevel    : 8059
    TrackNumber     : 1
    title           : Amours
    author          : Louise Attaque
    copyright       :
    comment         :
Output #0, s16be, to 'C:\Users\Didier\AppData\Local\Wild Media Server\WMS\Temp\T
est_a43145bdd4ffb3f69854f2fbf9353674.s16be':
    Stream #0.0(eng): Audio: pcm_s16be, 44100 Hz, 2 channels, s16, 1411 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
size=   20272kB time=117.68 bitrate=1411.2kbits/s
C:\WMS>pause
How to solve this ?
DLOQUET wrote: I think I have the same problem with accented characters in French.
How to solve this ?
Try switching to the Regional Settings (Control Panel) the language for non-Unicode programs to French.
DLOQUET
Post by DLOQUET »
unfortunatly, settings were already in french for non unicode programs
DLOQUET wrote:unfortunatly, settings were already in french for non unicode programs
What operating system?
DLOQUET
Post by DLOQUET »
Vista edition familiale premium
SP2
DLOQUET wrote:Vista edition familiale premium
SP2
Try "Run As Administrator", the program can create symbolic links to the problematic media-resources,
the program can create hard links to the problematic media-resources (not need to run "Run As Administrator", but require a change wms.cfg in notepad <HardLinksDirectory>\WmsLinks</HardLinksDirectory>)
