Update file from version 1.07 (1.07-1.08.2) (1.08rc2-1.08)
How to update the program:
1. Download the update file.
Wild Media Server (UPnP, DLNA, HTTP) v.1.08
1. Added device configuration:
- "Apple iPad/iPhone/iPod (DLNA, 14:9, 480x320, AirPlayer)"; - transcoding on the fly;
- "Apple iPad/iPhone/iPod (DLNA, 14:9, 480x320, PlugPlayer, 8Player, MLPlayer, LMPlayer, MediaBrowser)"; - transcoding on the fly;
- "Apple iPad/iPhone/iPod (Web, 14:9, 480x320, Safari)" - transcoding on the fly;
2. The ability to use a script to create Web-navigation pages (Settings - Device - "Web-navigation" - Script),
default script - http://www.wildmediaserver.com/forum/vi ... f=19&t=742.
3. Added a Dutch translation files (thanks to the user aka Reneweesp).
4. The distribution includes a French translation file (thanks to the users aka Fred from lyon, Lecureuil).
5. Updated subtitle module (changes for PGS-subtitles).
6. Changes in support of the UDF disk images.
7. Added registration SSIF-files (3D), perhaps some devices support work with SSIF-files in DLNA-mode; FFMPEG, TsMuxer not support MVC (Multi View Coding).
8. Added events "After program start" , "Before program exit", "Before server start", "After server start",
"Before server stop", "After server stop", "Server idle (30 minutes)" (Settings-Additional-Events).
9. Added settings for size and duration of transcoder probe when scanning files (Settings-Transcoder-Other),
can be used, if not determined by scanning all tracks.
10. Updated module MediaInfo.
11. Added selection of video codec MPEG4, X264 for transcoding.
12. Updated transcoder FFMPEG (SVN-r25702) - added parameters vstreamid, astreamid -
selection of video and audio tracks for transcoding (without map).
Update to version 1.08.3 (1.08.2-1.08.3)
- in the settings of podcasts added "Priority of video formats" (setting should be used in the scripts links to video, examples: Youtube, Hulu, MTV, Fox, BBC iPlayer, CNN);
- in the settings of podcasts added schedule for update (button Schedule);
- in the settings of podcasts added the possibility of customization for client devices (button "Devices");
- libraw-lite.dll replaced on libraw.dll (support for digital cameras RAW-files);
- in the settings of client device added "Working time";
- changes for reading genre in mp3-files;
- added mode "Indicator of availability of the Internet resources" (Settings - "Media-resources" - "Internet-resources" - "Check the availability of Internet resources").
Update to version 1.08.4 (1.08.3-1.08.4)
- added settings for loading custom playlists (Settings - Playlists);
- individual transcoding settings of movie (List [Movies] - select a file - right click - "Special settings...");
- updated Bulgarian, German translation files;
- updated subtitles module.
Released a version "Wild Media Server (UPnP) v1.08.4"
Re: Released a version "Wild Media Server (UPnP) v1.08"
Update to version 1.08.1 (1.08-1.08.1)
- updated transcoder FFMPEG - support wtv-files;
- changes for FLAC-files with ID3 tags;
- changes for MP3-files with variable bitrate (wrong Duration);
- added registration dvr-ms files by default.
Re: Released a version "Wild Media Server (UPnP) v1.08.1"
Update to version 1.08.2 (1.08.1-1.08.2) (1.08-1.08.2)
- fixed a problem updating some podcasts through the navigation of media device;
- "The list of authorized network connections", "The list of autohorized client devices" - added column on / off working the program with the connection, device;
- in the ip-address of connection or device, you can specify a mask (you can use *, [], ?) or just empty ip-address. May be useful for devices receiving the ip-address via DHCP.
To check the activation code is required to specify the exact ip-address ![Exclamation :!:](./images/smilies/icon_exclaim.gif)
Re: Released a version "Wild Media Server (UPnP) v1.08.2"
I there a way to update from 1.07.3 ?
when I use the ws107108.2.wsr, Iget errors because the version differs![Sad :(](./images/smilies/icon_e_sad.gif)
I don't want to reinstall WMS, because right now everything is working fine.
Use the distribution kit - http://www.wildmediaserver.com/download.php (no need uninstall)w00kie wrote:I there a way to update from 1.07.3 ?
Re: Released a version "Wild Media Server (UPnP) v1.08.3"
I'm currently on version 1.08rc1 and can't find and update from this version to the latest.
Please advise.
Regards,
Kevin.
Please advise.
Regards,
Kevin.
Use the distribution kit - http://www.wildmediaserver.com/download.php (no need uninstall)kc69 wrote:
Please advise.
how does...
" in the settings of client device added "Working time";"
work?
work?
Settings - Server - "The list of authorized client devices" - choose a device - Edit - "Working time"hepple wrote:how does...
work?
