Thanks Eugene !
I put my finished script below - may be useful to someone. Running this script creates a directory 'Open.FM' in which it links to all the radio stations available on the portal open.fm (77 items). Each station has turned profile transcoding 'Music (VLC) - MP3' (works best for me).
BTW - WMS is the best !
  iSuccessCount: Integer;
  vOpenFMList: Variant;
  title: String;
  tmpStr: String;
  x: Integer;
  y: Integer;
  url: String;
  AllMusicFolder, OpenFMFolder, tmpF: TWmsScriptMediaItem;
  mpiTranscodingProfile = 50;
function JsonDecode(const aText: string): string;
  i, j : integer;
  i := Pos('\', aText);
  if i = 0 then
    Result := aText
  else begin
    Result := Copy(aText, 1, i - 1);
    j := i;
    repeat
      if (aText[j] = '\') then begin
        inc(j);
        case aText[j] of
          '\': Result := Result + '\';
          '"': Result := Result + '"';
          '''': Result := Result + '''';
          '/': Result := Result + '/';
          'b': Result := Result + #8;
          'f': Result := Result + #12;
          'n': Result := Result + #10;
          'r': Result := Result + #13;
          't': Result := Result + #9;
          'u':
              Result := Result + Chr(StrToInt('$' + Copy(aText, j + 1, 4)));
              inc(j, 4);
      end else
        Result := Result + aText[j];
      inc(j);
    until j > length(aText)
  iSuccessCount := 0;
  AllMusicFolder := WmsFindMediaFolder(mfAudioAllMusicItemID);
  if (AllMusicFolder <> nil) and (AllMusicFolder.ChildCount > 0) then begin
    OpenFMFolder := WmsFindMediaFolder(mfAudioInternetRadioItemID, 'Open.FM');
    if OpenFMFolder <> nil then begin
        OpenFMFolder.DeleteChildItems;
        OpenFMFolder.Delete;
    OpenFMFolder := WmsFindMediaFolder(mfAudioInternetRadioItemID);
    OpenFMFolder.AddFolder('Open.FM');
    WmsShowInformation('Load metadata...');
     try
        vOpenFMList := WmsDownloadURL('http://open.fm/getplaylist.php');
        i := 0;
        while 1 do
          i := i+1;
          x := NPos('{"title":', vOpenFMList, i);
          if (x<1) then break;
          y := NPos('"gg"', vOpenFMList, i);
          tmpStr := Copy(vOpenFMList, x+1, y-x-2);
          if (Length(tmpStr)>0) then
             title := ReplaceStr(ExtractWord(2, ExtractWord(1, tmpStr, ','), ':'), '"', '');
             id := ReplaceStr(ExtractWord(2, ExtractWord(2, tmpStr, ','), ':'), '"', '');
             url := 'http://gr-relay-5.gaduradio.pl/' + id;
             //MessageDlg(url, mtInformation, mbOK, 0)
             WmsCreateMediaItem(url, OpenFMFolder.ItemID);
             tmpF := WmsFindMediaFolder(OpenFMFolder.ItemID, url);
             tmpF.Properties[mpiTitle] := NameCase(Lowercase(JsonDecode(title)));
             tmpF.Properties[mpiTranscodingActive] := True;
             tmpF.Properties[mpiTranscodingProfile] := 'Music (VLC) - MP3';
             iSuccessCount := iSuccessCount + 1;
    finally
      WmsHideInformation
  if iSuccessCount > 0 then
    MessageDlg('Load Open.FM list was successful.', mtInformation, mbOK, 0)
  else
    MessageDlg('No information available for load.', mtError, mbOK, 0);
  WmsDatabaseAutoSave;
  ProcessMediaResult := True
Regards,
Koczis
