does anybody know how why the last 15 seconds doesnt play ?
All worked fine but at the end of the film the last seconds are cut off.
Thx
Matthias
WMS doenstn play the Last 15 Seconds....
Re: WMS doenstn play the Last 15 Seconds....
Hi Matthias,Blaehhals wrote:Hi,
Thx
Matthias
This happened to me before. Choosing the option "chuncked transfer" should resolve your issue.
Do you have another solution?trevorsem wrote:Hi Matthias,Blaehhals wrote:Hi,
Thx
Matthias
Chunked mode does not provide a good quality, there are freeezes on the video.
Chunked mode does not affect the video quality, it affects the data transfer mode.vincek02 wrote:Do you have another solution?trevorsem wrote:Hi Matthias,Blaehhals wrote:Hi,
Thx
Matthias
Perhaps you lack the speed of transcoding, it must be greater than the frame rate.
when I does not chunked mode the video is perfect.
What should I do concretely?
Is there a planned fix for the problem of cut before the end of the video?
Have you tried playing movies in the mode Chunked without transcoding ? Any problems?vincek02 wrote:when I does not chunked mode the video is perfect.
The problem relates to devices, they do not play all the data after disconnect.vincek02 wrote: Is there a planned fix for the problem of cut before the end of the video?
The problem is the sameEugene wrote:Have you tried playing movies in the mode Chunked without transcoding ? Any problems?
My device is samsung UE32C5100, What are the best settings to avoid this?
If transcodes in m2ts-format, check the DLNA-profile, it should be MPEG_TS_HD_NA_T (Settings - File types).vincek02 wrote:The problem is the sameEugene wrote:Have you tried playing movies in the mode Chunked without transcoding ? Any problems?
I'm confused, the problem with periodic freezes or absence of the last seconds ?
I checked on Samsung BD Player, 15-seconds video - complete playback with transcoding.
I want to fix the problem of the last second but i can't use the chunked mode to fix it because freeze, or tell me which setting to use with chunked mode to solve freeze probleme.Eugene wrote:If transcodes in m2ts-format, check the DLNA-profile, it should be MPEG_TS_HD_NA_T (Settings - File types).vincek02 wrote:The problem is the sameEugene wrote:Have you tried playing movies in the mode Chunked without transcoding ? Any problems?
another issue?
excuse my english i'm french :-/
If your TV does not support Chunked mode, you can use the settings "Close connection after transcoded file transfer in ? seconds" (Settings - Device)vincek02 wrote:I want to fix the problem of the last second but i can't use the chunked mode to fix it because freeze, or tell me which setting to use with chunked mode to solve freeze probleme.Eugene wrote:If transcodes in m2ts-format, check the DLNA-profile, it should be MPEG_TS_HD_NA_T (Settings - File types).vincek02 wrote:The problem is the sameEugene wrote:Have you tried playing movies in the mode Chunked without transcoding ? Any problems?
