WMS Service memory usage
Re: WMS Service memory usage
airzone wrote:I'm curious to see if anyone else has noticed this:
I have WMS running as a service successfully. When I am transcoding rmvb files (using Real Alternative codec), the WMS service memory usage shoots up to 650 odd megs. The rmvb files aren't anything special - 200mb / 45 minute tv episodes. The memory won't be released unless I restart the WMS service. When I am transcoding an avi to include subtitles, the WMS service sits at around 240mb instead.
What transcoding profile is used?
airzone wrote:The profile is Movies - TsMuxer
n.b. After playing an AVI, the service will release it's memory after a minute or so. It doesn't seem to be doing so with rmvb.
edit: Playing mkv, which also uses Movies - TsMuxer, consumes ~200 - 250mb. This is also released after a few minutes. In addition, tsmuxer.exe consumes around 250mb.
Transcoding profile "Movies - TsMuxer" does not use "Real Alternative codec"
I could not repeat the problem, but perhaps it is related to the use of transcoding buffer.
airzone wrote:
With the latest Real Alternative and WMS 1.07, the problem still exists.
I have deactivated the service and will try and run without to see if the problem exists still. Unfortunately I don't know where to look to change the transcoding buffer size
Settings-Transcoder-Other
