Unable to get DTS to play on PS3
I am playing a MKV file with a DTS track via PS3. The audio comes through but not as DTS. What settings should I be using for this? So far I love the software. Just having this one little issue.
Re: Unable to get DTS to play on PS3
PS3 not support DTS via DLNA.jakefoot wrote:I am playing a MKV file with a DTS track via PS3. The audio comes through but not as DTS. What settings should I be using for this? So far I love the software. Just having this one little issue.
Thanks. Do you know if the Sony Bravia TVs do? I have KDL-52XBR9. Appreciate the help.
As far as I know, Sony TVs do not yet support DTS, the support is in Blueray-players.jakefoot wrote:Thanks. Do you know if the Sony Bravia TVs do? I have KDL-52XBR9. Appreciate the help.
Bummer. Thanks again for the knowledge.
Just an update here.
You can play DTS audio on your PS3 (as long as your audio unit can handle DTS of course).
Download "mkv2vob" which is a rather clever little program that converts an mkv file with video (usually h264) and audio (DTS) into a patched vob file that will play on your PS3. The file will probably not play on many other media players.
Settings - Transcoder - "Codecs, frame" - "Hide DTS in LPCM"bhwsyd wrote:Just an update here.
