Hello Eugene,
I am trying to play .iso files. I see the files in the menu, but I cannot select the .iso file and that it starts playing the movie. It only enters the iso files and I can select the different .vob files.
Is it possible to only select the .iso file and that the movie starts playing.
Thanks!!!
Regards,
Geert
Playing .iso files on Philips 37PFL9604H
Re: Playing .iso files on Philips 37PFL9604H
For DVD, you can use the mode "Creating folders DVD-structure for DVD-directories" (Settings-Scanning).geert wrote: I am trying to play .iso files. I see the files in the menu, but I cannot select the .iso file and that it starts playing the movie. It only enters the iso files and I can select the different .vob files.
The setting is already in use.
I have attached some print screens.
Regards,
Geert
Regards,
Geert
I still haven't found a solution for playing iso files on my Philips TV.
The iso file is made using CDBurnerXP or IsoBuster.
I can see the iso file in the menu, but when I select it I get submenu's with the different .vob files.
How can I play the iso file?
Thanks!!!
Thanks!!!
