Hi.
Here in Norway (and also New Zeeland i have heard) the national terestial broadcaster (RiksTV) uses MPEG-4 with H.264 and HE-AAC.
When recording with DVBwiever I get TS-files that I'm unable to play from WMS. Video is ok, but sound is not recognised.
Support for HE-AAC would be verry nice and give me a cool PVR function. (DVBviewer is using LIBFAAD2 to decode the sound during direct playback http://www.dvbviewer.info/forum/index.p ... opic=23347, and also VLC-player is able to play these TS-files..)
br
kaNor
Support for HE-AAC audio
Re: Support for HE-AAC audio
If you upload the sample file on rapidshare.com, then I will check what can be done.kaNor wrote: Here in Norway (and also New Zeeland i have heard) the national terestial broadcaster (RiksTV) uses MPEG-4 with H.264 and HE-AAC.
Short example kan be downloaded here: http://rapidshare.com/files/377813350/N ... en.ts.html
This file also includes DVB subtiltles in Norwegian.
I can uppload a longer video if required.
Settings-Transcoder-Profiles-AddkaNor wrote:Short example kan be downloaded here: http://rapidshare.com/files/377813350/N ... en.ts.html
Transcoding parameters:
"<VLC>" -Idummy --language=en --sout=#transcode{vcodec=mp2v,vb=12000,width=720,height=406,scale=1,acodec=mpga,ab=192,channels=2,samplerate=48000}:duplicate{dst=std{access=file,mux=mpeg1,dst="<OUTPUT FILE>"}} "<INPUT FILE>" vlc://quit
Choose transcoding profile "Movies (VLC)" on right click mouse.
Did as you said, an know I get "File could not be found/played" instead of video with no sound...
BUT also good news: When I run Test transcoding from right click, and places the outputed .mpg-file in video library, I'm able to play that file and get sound.
A cind of "missing link" when transcoding "on the fly" ? Any Idea ?
kaNor wrote:Did as you said, an know I get "File could not be found/played" instead of video with no sound...
Aaaaah, a good nights sleep and answer arrived;
I was running as a windows service, and on Vista there is missing rights for running VLC from that service.
Now I'm able to run my recorded TS-files directly with sound.
NICE
Version 1.00 adds support for transcoding using the "Movies (primary)"kaNor wrote:Short example kan be downloaded here: http://rapidshare.com/files/377813350/N ... en.ts.html
