Some questions
utillity
Some questions
Post by utillity »
Hi!
wow! this seems to be the first app to run on windows2008 core and deliver content to my Samsung devices. Thanks alot for this! Working a bit with it I have the following questions:
1. I have alot of DVDs in my collection - for all only the filenames get listed. I found a way to manually set the names (right-click "edit information", but it would be great, if I could "quickly" name all VOBs of a DVD.
2. After naming them accordingly, I see that they are also (as expected) listed multiple times (once for each VOB). is there a way to make it appear as ONE file to a DLNA client? The "Join for View" option (BTW: a non-english confirmation-dialog pops up) does not seem to do the trick.
3. it would be cool to drag/drop file onto the genres
4. it seems sometimes the server disappears from the list of servers on the client. is this normal?
regards, utillity
regards, utillity
Re: Some questions
utillity wrote: 1. I have alot of DVDs in my collection - for all only the filenames get listed. I found a way to manually set the names (right-click "edit information", but it would be great, if I could "quickly" name all VOBs of a DVD.
Select files - Edit information
utillity wrote: 2. After naming them accordingly, I see that they are also (as expected) listed multiple times (once for each VOB). is there a way to make it appear as ONE file to a DLNA client?
In folder Transcoding is performed merge files into one file. You can also use the mode "Create folders DVD-structure" (Settings-"Media-Resources"-Scanning)
utillity wrote: The "Join for View" option (BTW: a non-english confirmation-dialog pops up) does not seem to do the trick.
Thank you for your message, will be corrected in the next version.
utillity wrote: 3. it would be cool to drag/drop file onto the genres
This happens automatically if the information is filled.
utillity wrote: 4. it seems sometimes the server disappears from the list of servers on the client. is this normal?
Possible problems with the firewall, must open port UDP 1900 (IN/OUT)
utillity
Re: Some questions
Post by utillity »
hi eugene, thanks for your help on this,
ad 1) edit information will not let me change the name, if multilpe items are selected. Only genre, etc.
ad 2) I've activated Create folders DVD-structure, but see no difference in the client? what could be the cause?
ad 3) yes, but if it's not filled in yet, this would be a quick/easy way to do so (and then save the metadata)
ad 4) thanks, will try
regards, utillity
Re: Some questions
utillity wrote: ad 1) edit information will not let me change the name, if multilpe items are selected. Only genre, etc.
Yes, the field is locked, I think no need to change it, on the client device will not understand how to choose the file.
utillity wrote: ad 2) I've activated Create folders DVD-structure, but see no difference in the client? what could be the cause?
For DVD-structures create special folders.
utillity wrote: ad 3) yes, but if it's not filled in yet, this would be a quick/easy way to do so (and then save the metadata)
Edit genre, quick and easy.
utillity
Re: Some questions
Post by utillity »
hi again, eugene
ad 1) the device (my samsung TV) shows this name, if set. otherwise the filename is shown, which is not an option, when you have many files
regards, utillity
