markjen73 wrote:
changed device to PS3 1920x1080 and tried using Flac-LPCM profile, no luck. Switched transcode to mp3 with profile Music-Primary and it works! Plays both .flac and mp3 files.
Now my question is...do I load all my 5300+ files all at once? Does WMS go through the whole library and transcode everything or does it only transcode the one that is playing? Just afraid that throwing all those files at it at once will make it hang. Suggestions?
The Transcoding Parameters window is full of code. Do I delete all that code and paste in: -i "<INPUT FILE>" -f mp3 -acodec libmp3lame -ab 320000 -ar 48000? Or do I append it on to the end, the beginning or what?
By the way, tried scanning all 5300 media files again and WMS became "not responding".
Not sure what you're saying. Do you not want to help me? I can go elsewhere if that's what you're suggesting... guess this is how you get people to buy your software when the trial is over?
Did you read my post? I asked where to put the code in the transcoding parameters window.
markjen73 wrote:Not sure what you're saying. Do you not want to help me? I can go elsewhere if that's what you're suggesting... guess this is how you get people to buy your software when the trial is over?
I think this program is too complicated for you, perhaps in the future it will be easier for you, good luck.
