sharing with multi consoles
lucas22
Post by lucas22 »
hi
how can i share to sony ps3 and x box 360 without having to go back and select them from the list every time.
also when trying to use the 360 to stream internet radio the setting does not appear in the dashboard when wms connect is pressed, it just gives me albums,artists,saved playlists,songs etc but no option for internet radio.
any help would be very much appreciated.
Re: sharing with multi consoles
Hi
lucas22 wrote:hi
Settings-Server-A list of allowed client devices - Search - for each device you can specify its configuration.
If you have on the XBox a folder Playlists, they are there.
