Recently my online video provider implemented a security measure where I need to supply login credentials in the video url. Ok, no problems there, but the url returns an mms url instead of http with a temporary session id. For example the url http://www.bestrussiantv.com/tv_request ... e=-1&pid=2 will return mms://38.117.74.178/ch1?sid=BDA2A9014DBB3224903ABBE4A7 when processed. The problem is the sid is temporary and will get invalidated after a while. Is it possible to fix this problem?
Thank you
BTW It works with Tversity without this problme but I don't like Tversity because it doesn't playing ISO files and when it streaming TV it stopping very often
Please help - online video with login credentials in the url
Re: Please help - online video with login credentials in the url
VLC does not work with the original link ?grafcable wrote:Recently my online video provider implemented a security measure where I need to supply login credentials in the video url. Ok, no problems there, but the url returns an mms url instead of http with a temporary session id. For example the url http://www.bestrussiantv.com/tv_request ... e=-1&pid=2 will return mms://38.117.74.178/ch1?sid=BDA2A9014DBB3224903ABBE4A7 when processed. The problem is the sid is temporary and will get invalidated after a while. Is it possible to fix this problem?
Thank you
It works until sid changed. After that I need to change all links again. In Tversity it works permanently even sid has been changed.
I don't know why but VLC doesn't use HTTP and transfer the link to MMS.
This is the log of test of transcoding:
C:\Program Files (x86)\Wild Media Server>"C:\Program Files (x86)\Wild Media Serv
er\wmsmpeg.exe" "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" -Idummy --language
=en --sout-ffmpeg-strict-rc --sout=#transcode{vcodec=mp2v,vb=8000,fps=24,width=7
20,height=576,scale=1,aspect=16:9,acodec=mpga,ab=192,channels=2,samplerate=48000
}:duplicate{dst=std{access=file,mux=mpeg1,dst="C:\Users\Graf\AppData\Local\WILDM
E~1\WMS\Temp\Test_7b380b2b64acc98b166fc94c72801f28.mpg"}} "http://www.bestrussia
ntv.com/player/stream.ashx?sid=xxxxxxxxxxx&idName=channel&idProgram=1&tz=180"
[02b76cfc] dummy interface: VLC media player - version 1.0.5 Goldeneye - (c) 199
6-2010 the VideoLAN team
[02b76cfc] dummy interface: using the dummy interface module...
[02b6fac4] mux_ps mux: Open
[02b6dab4] ts demux error: cannot peek
[02b6fac4] mux_ps mux: Close
[02b6fb9c] mux_ps mux: Open
[02b68bbc] access_mms access: selecting stream[0x1] audio (49 kb/s)
[02b68bbc] access_mms access: selecting stream[0x2] video (1378 kb/s)
[02b68bbc] access_mms access: connection successful
And this is not working link:
E~1\WMS\Temp\Test_38daf9f0a6ccd2adfe5d474299f05d61.mpg"}} "http://www.bestrussia
ntv.com/player/stream.ashx?sid=xxxxxxxxxxx&idName=channel&idProgram=5&tz=-480"
[02adeb2c] dummy interface: VLC media player - version 1.0.5 Goldeneye - (c) 199
[02adeb2c] dummy interface: using the dummy interface module...
[02af0cf4] mux_ps mux: Open
[02aeece4] ts demux error: cannot peek
[02af0cf4] mux_ps mux: Close
[02af0dcc] mux_ps mux: Open
warning: first frame is no keyframe
[02af0dcc] mux_ps mux: Close
Probably need to use primary source of links without sidgrafcable wrote:It works until sid changed. After that I need to change all links again. In Tversity it works permanently even sid has been changed.
That what I'm using. Site has direct link to all channels and it in http. But as I said VLC is converting it to mms
http://www.bestrussiantv.com/player/stream.ashx?sid=xxxxxxxxxxx&idName=channel&idProgram=1&tz=180"grafcable wrote:That what I'm using. Site has direct link to all channels and it in http. But as I said VLC is converting it to mms
They have only direct links with sidEugene wrote: Probably need to use primary source of links without sid
By http-address is a reference to mms, it is usual practice, when not working, try to open in VLC.Eugene wrote:http://www.bestrussiantv.com/player/stream.ashx?sid=xxxxxxxxxxx&idName=channel&idProgram=1&tz=180"grafcable wrote:That what I'm using. Site has direct link to all channels and it in http. But as I said VLC is converting it to mms
But how it works with Tversity? I use the same links
No problem, use Tversity.grafcable wrote:But how it works with Tversity? I use the same links
