List songs by album track number?
Re: List songs by album track number?
Help - Last changes
Wild Media Server (UPnP, DLNA, HTTP) (version 1.05)
To create the playlists, do as you mentioned, and then drag and drop categories onto the playlist name. Expand the playlist name and the hierarchy will show up under Grouping. Just drag and drop more categories to build up the structure. These are the playlists I use (and the settings to make it work):
Genre
- Just drag and drop "Genre" onto the name
Genre / Artist (sorted by year, album, track number)
- Genre
- Artist (right click and set sort to: +mpYear,+mpAlbum,+mpTrack)
Genre / Artist / Album
- Genre
- Artist (set sort to: +mpYear,+mpAlbum)
- Album (set sort to: +mpTrack)
Genre / [A]rtist (could also be called Genre / ABC / Artist)
- Genre
- Artist (edit and replace expression with:
ReplaceStr((UpperCase(Copy(Trim(mpAuthor), 1, 1))), ",", #13#10)
- Artist (set sort to: +mpYear,+mpAlbum,+mpTrack)
Genre / [A]rtist / Album
- Genre
Genre
- Genre
- Genre
- Genre
- Genre
When trying to listen to the mp3 music on my iradio, i see all of musics without any folder, like artist and, genre, is possible that the stream player could have that option?
Select songs for playlist
Some questions on playlists.
1. Can I make a selection of my music library?
I would like e.g. ONLY genre=Classical
or File-path=C:\Data Media\MediaMonkey\ AND NOT Genre = Classical
2. I would like to make different playlists for compilations. So I would like
ONLY music with mp3-tag Compilation=True (or "1").
More general: can I somehow access the data in mp3-tags that I don't see in the columns of WMS ?
3. In iTunes, they use Groupings, which is useful for classical music. In the mp3-tag it is field Contentgroup. Is this somehow available? I can't find it in the columns.
Hope someone can help, thanks.
WMS 1.50.3 / TV Panasonic Viera TX-L37DT35E
Re: Select songs for playlist
1. Drag and Drop column header "Genre" to folder PlaylistsMartinSch wrote:Some questions on playlists.
2. Playlists - Genre - Grouping - "ReplaceStr(mpGenre, ',', #13#10)" - right click - Edit
3. "Allowed values" - Classical
1. ...MartinSch wrote: or File-path=C:\Data Media\MediaMonkey\ AND NOT Genre = Classical
2. ...
3. Expression grouping - Edit - Expression
if SameText(ExtractFilePath(mpFilePath), 'C:\Data Media\MediaMonkey\') and not SameText(mpGenre, 'Classical') then
FolderPath := 'MyGroup'
else
FolderPath := 'Other'
"Allowed values" - MyGroup
You can not do through the WMS-functions, but can use external Ole-objects to access the mp3-tagsMartinSch wrote: 2. I would like to make different playlists for compilations. So I would like
Eugene wrote:1. ...MartinSch wrote:Some questions on playlists.
2. ...
3. Expression grouping - Edit - ExpressionOkCode: Select all
begin if SameText(ExtractFilePath(mpFilePath), 'C:\Data Media\MediaMonkey\') and not SameText(mpGenre, 'Classical') then FolderPath := 'MyGroup' else FolderPath := 'Other' end.
OK, this looks hopeful, but it does not work. After I lot of trial and error I found the reason: my mp3's are in SUBfolders of C:\Data Media\MediaMonkey\.
I probably need something like "Trim(mpFilePath,1,26)". Tried different combinations, but no succes.
Do you have a manual for this kind of code (it's not in "UPNPresources"!) or can you help? Thanks!
You can try
or
Quick help on the right
if (Pos(Uppercase('C:\Data Media\MediaMonkey\'), Uppercase(ExtractFilePath(mpFilePath))) = 1) and not SameText(mpGenre, 'Classical') then
if MatchText(ExtractFilePath(mpFilePath), ['C:\Data Media\MediaMonkey\'], True) and not SameText(mpGenre, 'Classical') then
Thats really great Eugene, thanks a bunch! Now I can make really beautiful navigation for my music library, much better than on the iPod, even better than on iTunes.Eugene wrote:You can try
Paytime for MartinSch.
List songs NOT by album track number?
Sorry, been studying but don't get it.
I would also like to list the tracks by Song title ("Track name"). But in front of the name is the track number. How do I get rid of the track numbers in front of the song. Is it possible to simply use the tag of the trackname?
