Thanks, I reproduced the problem. In my case helped Chunked (Settings - Server - choose "Blu-ray Disc Player" - Edit - Settings - turn on Chunked). I will try to solve the problem with the default settings.bnorrish wrote:Just sent you RapidShare link to support@wildmediaserver.com.
Sony BDP-S470 FLAC Files - Occaional errors
Re: Sony BDP-S470 FLAC Files - Occaional errors
Clunking resolved. I do not believe I was saving the setting properly on your first suggestion - still learning the GUI.
One note - the progress bar for the song on the DVD display on the TV no longer functions with this setting. Not a real big issue for me - I just wanted to note it.
Thanks for the help.
Yes, this is a feature player. Fix with the default settings will be in the next version - I seem to have found the solution.bnorrish wrote:Clunking resolved. I do not believe I was saving the setting properly on your first suggestion - still learning the GUI.
http://www.wildmediaserver.com/forum/vi ... f=18#p5524
Required re-reading the file properties - stored more precise the value of duration.
