I managed to force WMS trial to stream videos to Sharp Aquos 46le824e. It plays all right but only videos longer than 30 minutes. Every file that is shorter than half an hour cannot be streamed ( an error message appears) no matter what video format was used for coding.
Any ideas?
Z0rr0
Short videos problem
Re: Short videos problem
Can be help: Settings - Device - turn on Chunkedz0rr0 wrote: I managed to force WMS trial to stream videos to Sharp Aquos 46le824e. It plays all right but only videos longer than 30 minutes. Every file that is shorter than half an hour cannot be streamed ( an error message appears) no matter what video format was used for coding.
It was turned on already, so it did not help. But I changed "File size for transfer start" to 2048 and suddenly it sterted to work.
Still cannot stream pictures and MP3's alas ;-(
What kind of problems?z0rr0 wrote:Still cannot stream pictures and MP3's alas ;-(
Cannot see any of my mp3's and pictures. In manual of my tv set it is said it's possible to stream only lpcm format and non progresive jpegs. As for mp3's i chose wave in transcoder settings - still no files
Maybe your TV has separate navigation for movies, music, photos. The correct section?z0rr0 wrote:Cannot see any of my mp3's and pictures. In manual of my tv set it is said it's possible to stream only lpcm format and non progresive jpegs. As for mp3's i chose wave in transcoder settings - still no files
LPCM - it can be s16be
Settings - Device - "Embedded file suport" - Music - remove all
Settings - Transcoder - Transcoding file parameters - Music - Extension - click button - s16be
or (individual settings of device)
Settings - Server - choose a device - Edit - Settings - "Embedded file suport" - Music - remove all
Settings - Server - choose a device - Edit - Settings - "Subtitles, transcoding file" - Transcoding file parameters - Music - Extension - click button - s16be
