Nice program
I work with the program under windows xp en under linux via Wine
Under linux the subtitles the *.srt are not shown on my Sony 46Z5500
Under Windows XP there is no problem
Any idea
Greetings from the Netherlands
subtitle support under linux via wine
Re: subtitle support under linux via wine
In Wine there were problems with the use GdiPlus, which is used for the subtitles, so the subtitles do not work. I need to check again on the latest versions of Wine, the information will be later.wim wrote: I work with the program under windows xp en under linux via Wine
Possible multi platform solution:
In some programs you see that subtitles are hardencoded into the video, so they are an integrated part of the video image
If Wild Media Server would have this option the problem is solved within Wild Media Server itself en creates a multi platform solution
Wtih regards
Wtih regards
Maybe I misunderstood. In WMS, you can connect any transcoder, which supports command line, OLE.wim wrote:Possible multi platform solution:
