helo
i have problem to configure my wms 1.03 to the tv when i play any kind of
video its not sreaming well
thanks for advance .
tv philips pfl9664 with wirless
Re: tv philips pfl9664 with wirless
Settings - Device - Embedded file support - check list of supported files, probably need to add mp4, avi.
If possible, connect the TV and computer wire or select a configuration device with a smaller frame size in transcoding file.maman_a wrote:helo
