I did not see any place to turn on the short identifiers. I do not see anything called Thumbnails, identifiers.
But, I don't know if I am using the correct version. I downloaded the latest, installed it and the About Box says it is 0.72 of 1.14.2010; is this not the 0.72.2 version you spoke of? Where do I get it?
What about two boxes?
Re: What about two boxes?
Link to the update file here http://www.wildmediaserver.com/forum/vi ... p=371#p371weaver4 wrote:I did not see any place to turn on the short identifiers. I do not see anything called Thumbnails, identifiers.
I did some experimentation and here is what I got.
Type: Popcorn
Short Identifiers: On
Authorize Server: On
Result: Error: Not Content Found on Server
Type: Popcorn
Short Identifiers: Off
Type: Popcorn
Authorize Server: Off
Result: Error: Server Time Out (never connected)
Type: Popcorn
Type: Popcorn XBOX
Result: Works!
What else should we try?
Type: Popcorn
Type: Popcorn
Type: Popcorn
Type: Popcorn
Type: Popcorn XBOX
Result: Works!
Thank you for tests, I think the device still requires folders IDs Windows Media Sharing. This will be for the Popcorn in the next version.weaver4 wrote:I did some experimentation and here is what I got.
Type: Popcorn
Type: Popcorn
Type: Popcorn
Type: Popcorn
Type: Popcorn XBOX
Result: Works!
I also have multiple devices...
With lots of effort I got NetGem IPTV-box working with WMS: no transcoding, with DTS audio etc.
The second box is Popcorn Hour A-200. I followed guidelines in this thread, renamed WD profile to Popcorn XBOX.
After setting HTTP 1.0 = on, I finally managed to get Popcorn playing videos.
Like GetGem, Popcorn also plays virtually any format but I can't configure WMS to send stuff without transcoding.
Biggest problem is with MKV. I can see from server CPU that WMS starts transcoding something but I do not know what/why. After 30 seconds picture starts to stutter, then I loose audio and finally the stream totally.
Please advice, what I need to do to send MKV without transcoding?
mpg, ts, vob, flac play fine with Popcorn. For all these I managed to get rid of transcoding.
Another issue: can't open jpg. All I get is 'Could not open' from Popcorn immediately after choosing the picture.
Settings - Server - choose a device - Edit - Settings - Embedded file support - Movies - * - Photo - *st72 wrote:
Been there, done that... does not help. MKVs seem to be transcoded, JPGs generate "Could not open".Eugene wrote:Hi,
The URL that Popcorn sees is "<some-cryptic-code>.mkv?infokey=.....". On server, process wms.exe hits to 25% CPU and almost exactly 30 secs later picture stutters and audio disappears.
Needless to say that both MKVs and JPGs play fine when opened via SMB. My MKVs are ripped from DVDs (MPEG2+AC3/DTS+DVDSUB), no HD video.
You can try update to 1.09rc1 (changes for url).st72 wrote:Been there, done that... does not help. MKVs seem to be transcoded, JPGs generate "Could not open".Eugene wrote:Hi,
Settings - Transcoder - turn on "Show transcoding panel", turn off DLNA 1.0, DLNA 1.5 (Settings - Server - choose a device - Edit - Settings)
I'm still in trial version, just few days leftcmk001 wrote:May be you need a 2nd licence for 2nd device.
The problem with MKV could be on the device (Popcorn) also, because I tested with Tversity and saw identical problems.
I'll check with NMT support forums and revert when necessary.
But the other problem with JPGs seems to be more WMS related because Tversity displays photos OK.
I'll update to version v1.09 and report later.
In the meanwhile I need to test my 3rd device (Sony BDP) before trial period expires.
