MSN.COM (http://video.msn.com)
MSN.COM (http://video.msn.com) - required version 1.77
msnvideos.zip
(7.74 KiB) Downloaded 2032 times
2. Drag and drop msnvideos.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "MSN.COM". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file msnvideos.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "MSN.COM - Explore", you can create first level of MSN.COM navigation.
Additional parameters - select the folder "MSN.COM" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
MSN region (http://video.aa.msn.com):
--regioncode=aa
Video count per folder (by default 30):
--itemsperfolder=NN
Date format (by default mdy)
--dateformat=dmy
