Australian ABC iView (http://www.abc.net.au/iview/)
Australian ABC iView (http://www.abc.net.au/iview/) - required version 1.77
abciview.zip
(4.17 KiB) Downloaded 1708 times
2. Drag and drop abciview.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Australian ABC iView". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file abciview.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Australian ABC iView", you can create or update first level of Australian ABC iView navigation.
Updated 2014/02/25
Re: Australian ABC iView (http://www.abc.net.au/iview/)
Updated 2014/02/25
