2. Drag and drop cbs.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "CBS". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file cbs.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "CBS", you can create or update first level of CBS navigation.
Additional parameters - select the folder "CBS" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=onCode: Select all
--videocount=NNCode: Select all
--subtitles=onCode: Select all
--videotype=on/off
