Discovery Channel (http://http://dsc.discovery.com/)
Discovery Channel (http://http://dsc.discovery.com/) - required version 1.77
discoverychannel.zip
(5.58 KiB) Downloaded 2037 times
2. Drag and drop discoverychannel.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Discovery Channel". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file discoverychannel.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Discovery Channel", you can create or update first level of Discovery Channel navigation.
Additional parameters - select the folder "Discovery Channel" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Video count (by default 25):
--videocount=NN
Subtitles support:
--subtitles=on
Re: Discovery Channel (http://http://dsc.discovery.com/)
Updated 2013/06/05
Updated 2013/10/31
Updated 2014/03/07
